EagleChief
- Jan 6, 2015
- 1,873
- 867
- Oklahoma
- 2014 Big Horn
- 5.7 Hemi
Your stock tires should be 33" already. I'm not real sure about the 2wd, but I wouldn't think 1 more in in tire height would cause an issue.thank you...yea, Sean at Maxtrac said that Id better do 33" tall only even with the 2.5" front coils. I thought for sure a 285/65 would work lifting nose 2.5".
But I can do a 275/65/20 and still do 2.5 coils, and I think it'd look about right too.
Probably cheaper too
Now ready to shoot me? Its a 2wd..so does that make a difference on height between 2WD and 4WD's?
You might look into the Bilstein's and see if they will work on your 2wd. If so, your upper control arms and ball joints will appreciate the Bils over a spacer kit.
