MaxTrac 4.5" Spindle 2wd lift
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
^ thank you. I will be buying this product.
Ktylor95
3.0 ecodiesel
Just put on my 4.5" spindle lift by maxtrac with 1.5" spacers in back
Got the shipment in today and couldnt wait. Started at about 2 and finished at about 630. Still have stock sized tires for now, but they are ATs so im a quarter of the way there.
THRASHER
v8
Looks good, I know you said that you still have the stock tires, just wondering what size tires you have on there now??? Also do have any pictures showing how much the wheels/tires stick out beyond the fenders.. I am looking at the same kit.. I just hate when the wheels/tires stick out a lot! Thanks in advance..
Ktylor95
3.0 ecodiesel
I highly recommend it, based on two days worth of driving, but ill be sure to update if i find anything out after a longer stretch.
VegasDragger45
Here's mine with 1.5" rear, 35/12.5/20 MT's and 20x12 -44 offset wheels
satxwy
Pentastar 3.6
Yes but only due to a few hundred pounds in the bed.
Ahh gotcha. I may be interested in that 4.5/1.5 kit in the future but I wouldn't want it sitting nose high. If you have some weight in the bed though, that makes sense.
Ktylor95
3.0 ecodiesel
be careful
I said id report back if i found any issues. I found an issue.
VegasDragger45
Holy cow, did you loop it up by the top of the spindle so al the slack was not by the tire?
Ktylor95
3.0 ecodiesel
I had loosened the bracket to get multiple pictures, but the line was originally set farther from the tire than that picture.
