KiltedCelt01
Your truck looks awesome, man. Very well done.
We need to bring back Truck of the Month to the forum. @JB1 gets my vote.
That truck looks so sick man. That is my goal right there with mine lol. I'm about to get a 6in rcx kit installed on mine with front bilsteins.
Just wondering, did you have to install new gears for the 37s?
Thanks, I have 3.92 gears and with the 8spd trans I haven't noticed any need for a lower ratio, it would be nice to have but not necessary.
One tip I can give you is select a 37" tire that weighs less than 80lbs and the lightest weight wheel you can afford (width adds weight). My 37's weigh just 4lbs more than a 35x12.50 nitto ridge grappler and 2lbs less than a 35x12.50 nitto trail grappler
What kind of numbers are you seeing for mpg? Truck looks great btw. I'm getting less than 15 mpg on a stock leveled truck, with the stock 20's...horrible so far. Probably just because it's learning my driving. My 6" lifted '16 1500 got around 15 mpg too, with 35" tires and 18" wheels! And some mods...
My Ram Night with BDS Lifted on 37's
Ground to Fender measurements:
Before: Front 36.75 and Rear 39.5 (2.75 rake)
After: Front and Rear both at 46.25
Parts List:
1. BDS Suspension Lift 6” front with optional 5” rear coils P/N 671H.
2. Zone Offroad Heavy Duty Upper Control Arm kit P/N D2301.
3. Bilstein 6112 60MM front struts with coils set @ 2.60” P/N 47-242548.
4. Bilstein 5100 46MM rear shocks P/N 33-185569 w/superlift 77-80038.
5. KMC XD-832 Wheels 20X9 -12mm offset 5x139.7 Hubcentric Satin Black
6. Yokohama Geolandar M/T G003 37X12.50R20 P/N 33337 (76.7 LBS).
