Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Lifted
Lifted
Need help with 5100s
This is a discussion on Need help with 5100s within the Lifted forums, part of the 4th Gen : 2009 - Present category!
Hi all new to the forum. I am about to inherit my dad's 2010 trx 4 and it needs shocks ...
Like Tree1Likes
Reply
Old 01-09-2017, 07:11 PM   #1 (permalink)
Ram Year: 2010
Engine: 5.7
Default Need help with 5100s
Hi all new to the forum. I am about to inherit my dad's 2010 trx 4 and it needs shocks all the way around. I'm wanting to do 5100s all the way around to level it in the front but I haven't found anywhere that says if the rear 5100s need at least one inch of lift to fit correctly. So the question is will the rear 5100s fit without a rear lift?
Sponsored Ad
Register to remove this ad.
Knightinraggedarmor is offline   Reply With Quote
Old 01-09-2017, 07:40 PM   #2 (permalink)
Ricks Ram's Avatar
Ram Year: 2014
Engine: Hemi 5.7
Default
Yes they will fit. They are capable of handling up to1" of lift but are fine for stock height as well.
DeereGuy likes this.
__________________
2014 Quad Cab Express 4x4 3:92 LSD 8 speed
32 Gallon fuel tank, Premium Cluster, RA4 Upgrade,Heated /Ventilated Seats,Heated Wheel upgrade. Power sliding rear window,Homelink, 6" BDS lift Bilstein 5100 shocks set one notch up, 20x9 Chrome fuell Hostage wheels,Toyo Open Country AT Extreme 35x12.5x20 tires.
Ricks Ram is offline   Reply With Quote
Old 01-09-2017, 08:36 PM   #3 (permalink)
Ram Year: 2015
Engine: Hemi 5.7
Default
What Rick said. I have front and rears on, stock height in back
Wrigley17 is offline   Reply With Quote
Old 01-09-2017, 09:42 PM   #4 (permalink)
Ram Year: 2010
Engine: 5.7
Default
Awesome, what setting do I need to set the front at to get a perfect level or slight squat and what would be the largest tire size I could clear?
Old 01-09-2017, 10:36 PM   #5 (permalink)
Ram Year: 2015
Engine: Hemi 5.7
Default
Most will say 2.1. You're truck is already set st .7 from what I've read here.
Old 01-09-2017, 10:54 PM   #6 (permalink)
MaizeNBlue's Avatar
Ram Year: 2016
Engine: Hemi 5.7
Default
+1 on the 2.1
MaizeNBlue is offline   Reply With Quote
Old 01-10-2017, 10:55 PM   #7 (permalink)
Ram Year: 2010
Engine: 5.7
Default
What would be the biggest tire I could fit after the level? I want to full the wheel well up
Old 01-11-2017, 04:28 AM   #8 (permalink)
Ram Year: 2013
Engine: 5.7 HEMI
Default
I'm 2.1 and rear 0.75. I just did 295/65/20 nitto G2 on the OEM wheels with no spacers. Zero issues! Mounted height is 3" over OEM.
Synolimit is offline   Reply With Quote
Old 01-11-2017, 08:11 PM   #9 (permalink)
Ram Year: 2010
Engine: 5.7
Default
Well Im wanting to put some 305s on it, those should fit right?
Old 01-11-2017, 08:56 PM   #10 (permalink)
Alaskanpeeps's Avatar
Ram Year: 2013
Engine: Hemi 5.7
Default
305/55/20 is a stock height tire. (33")
__________________
13 crew 4x4 hemi, 0/3 drop, 1000lbs helper bags, 305-50-20 Toyo At's
Alaskanpeeps is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bilstein 5100s Machete Lifted 22 04-26-2016 11:24 PM
Bilstein 5100s MoparManiac92 Lifted 4 11-07-2015 09:24 PM
eBay 5100s Tucker0074 Lifted 10 07-01-2015 05:59 PM
Bilstein 5100s for 2WD kris319 Lifted 7 06-12-2014 11:53 AM
Bilstein 5100s Tom McGrath Lifted 2 02-25-2014 09:39 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
