How was the 1.5" BL install? I was debating the 3" PA kit but damn think is almost $400 . Not sure that hassle and 1.5" is worth it. I like the $140 price of the 1.5". What's sad is I did 2.8" Bils and 1.5" BL on my 2011 lol. I just can't for the life of me remember how the bumper bracket install went hahaha. I know the body spacers were simple.
Edit- just read about all the fab work involved in running a 3" BL with my Amp Powersteps. 1.5" BL it is!!
Install was time consuming, but easy. Like you said the spacers were a piece of cake. The rear bumper wasn't too bad, however the front bumper was a little tricky. Just make sure you have a good drill bit to drill the new upper mount holes in the frame and you only get one shot so make sure you get them right the first time. The bumpers were the only part I wished I would've had a friend over to help me with. I ended up using a rolling jack and a 4x4 and hold the front bumper up while I lined it up. It actually wasn't that bad once I figured it out. I had to take it back off to make an adjustment and was able to get it back up and bolted down in less than 10 minutes. If you have a 2 piece bumper, don't follow their instructions for removal. They made me jump through a few unecessary hoops (i.e. removing the grille).
J Rod, was your kit from zone? And did you have to PB blast the body mount bolts to loosen them up or was it an air tool job? I'll be installing mine shortly and just wanted to know what i was in for? Thanks. OP sorry for jacking your thread.
Yes Zone, I did not use air tools but I did hit all of the bolts with PB blaster the night before. They all came out fairly easy. Oh and if you do it without air tools, don't plan on doing any heavy lifting for the next day or two.
