Need some quick help on lift install
kg93
AZ
So i started taking everything off today to install my lift.
I cant get the knuckle to pop off!
It is stuck on the lower control arm ball joint. I popper the top off but the bottom will not move no matter how much i beat that knuckle with a hammer.
has anyone run into the problem? I sprayed it down with wd40 but that didnt help
homebrew
Cummins
I'd say reinstall the upper at least hand tight then proceed to hit the lower with a bfh. If I remember correctly I also put a jack under the control arm to take some of the pressure off the ball joint.It took me a while but that's how I got mine loose.
kg93
kg93
AZ
hmm alright, ill do that + a heat gun and wd40
kg93
kg93
AZ
Any luck moving forward with this so far ?
negative, i had to put it on hold until tomorrow, got too cold and dark over here
DRkNESS
South Jersey
I'm sorry to hear that, and wish you well come tomorrow. :)
kg93
kg93
AZ
so i got all of that apart with a air chisel and a vice grip.
But i got almost no where today. Im stuck on the stupid ******* differential bolt. Top front bolt, there is no way to really get to it? Its stuck in place, i tried a cheater bar, right angle air gun, wrenches, i dont know what else to do, it wont budge and i cant get enough movement to do much.
Thats from the front of the truck between the front crossbar and the engine. Right next to it is the oil pan
gassersarentdead
ohio
You're not attempting to do this by yourself are you? As in no help?
Jake2544
MA
If I'm not mistaken, I used a long extension with a swivel on the end of the socket and used a pipe on the end of my breaker bar. Couldn't fit my impact gun in there. If that doesn't work try heating up the bracket with a torch first. I think that bolt and the upper rear shock bolts were the toughest to get at.
kg93
kg93
AZ
ill try doing that, i was using a ratchet and a big pipe, maybe i need to get even more leverage
kg93
kg93
AZ
Spray that ******* with PB Blaster too, works better than WD40.
i loaded it up with pb to sit over night, ill throw some more on tomorrow too
