Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Lifted
Lifted
New 2017 and lift options for standard cab short bed
This is a discussion on New 2017 and lift options for standard cab short bed within the Lifted forums, part of the 4th Gen : 2009 - Present category!
Good afternoon all, Last weekend I ended up trading in my 2012 Ram 1500 with a 4" RCX and Superlift ...
Reply
Old 01-07-2017, 01:02 PM   #1 (permalink)
WiSH2oo0's Avatar
Ram Year: 2017 1500 Express 4wd RCSB
Engine: Hemi 5.7
Default New 2017 and lift options for standard cab short bed
Good afternoon all,
Last weekend I ended up trading in my 2012 Ram 1500 with a 4" RCX and Superlift pieced together. This is my first brand new vehicle I have ever bought, I usually end up buying CPO to save a few bucks. Next week my new truck will be going in to have Line-X bedliner, rockers and wheel wells done. Hopefully this will help with all the salt used here in MN during the winter months.
So I ended up with a new 2017 Ram 1500 Express standard cab with a 6.4' bed. I was looking into the Superlift kit until I talked with the salesman on the phone. He told me they wouldn't recommend anything bigger then a 4" lift. They also expressed that I should buy adjustable lower control arms to correct the rear pinion angle to eliminate any rear drive shaft vibrations.
Next I called up Zone to see what they had to say. Their response was that either a 4" or 6" would be fine and I shouldn't have any problems at all with the rear drive shaft. I have to say after my first call to Superlift I was pretty bummed out that I bought my new truck and was in jeopardy of not being able to lift it.
So I'm now wondering if Zone is misinformed and I will indeed have to order adjustable rear lower control arms like Superlift had stated with there lift kit. Any help would be great so I can get this new toy in the air!
Thanks
Sponsored Ad
Register to remove this ad.
WiSH2oo0 is offline   Reply With Quote
Old 01-07-2017, 04:19 PM   #2 (permalink)
Dantheman's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
I'm assuming its 4wd? Lots of people have lifts on single cabs, not sure why it would be any different for a new truck unless something has changed on the suspension
__________________
2012 Ram 1500 Hemi CCSB Big Horn, 4x4, LSD, 6/3 BDS lift, Bilstein 5100 (waiting to be installed), 1.5" Bora wheel spacers, Nitto Terra Grappler G2 325/60R20, USCTJ Hidden Winch, Rigid Industries Dually Reverse Lights, Mopar CAI, Rear Seat Mod, Mopar Slush Mats
Dantheman is offline   Reply With Quote
Old 01-07-2017, 05:23 PM   #3 (permalink)
WiSH2oo0's Avatar
Engine: Hemi 5.7
Default
Yes it's a 4wd truck. The single cab short beds have a 120" wheel base vs the quad and crew cabs 140" wheel base. So maybe on my truck the rear drive shaft is shorter which would put more of an angle on the drive shaft itself. Which is why I believe that Superlift is worried about rear drive shaft vibrations. Maybe both front and rear drive shafts are shorter l wouldn't know without measuring both styles of trucks.
Old 01-07-2017, 06:19 PM   #4 (permalink)
Dantheman's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
Well you have a couple options. Put the lift on, and if the drive shaft is too short have it lengthened, which is not a big deal (This is the safest option). Or, this is a theoretical or, get a double cardan joint (H style yoke I believe) to extend it down and get a better angle at the same time. I believe the u joint size is 1-1/16" outer diameter, so you'd have to find the corresponding H yoke to make that work, assuming the diameter hasn't changed for a 2017. Any particular reason you're going with 4" instead of 6"?
Or measure the bolt pattern and have a machine shop make you a spacer out of aluminum.
I think you have enough options to not worry about not being able to lift but thats just my opinion. You could always do a leveling kit and body lift if it is really bothering you.
__________________
Old 01-07-2017, 06:34 PM   #5 (permalink)
yillbs's Avatar
Ram Year: 2016
Engine: 5.7 Hemi
Default
Pro-comp
__________________
The Bw44-44 transfer is case is probably one of the best cases on the entire planet ever to be created, or will be created.
yillbs is offline   Reply With Quote
Old 01-07-2017, 06:39 PM   #6 (permalink)
Dantheman's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
^ What? Pro comp doesn't even make a kit compatible with 2017s yet.
__________________
Old 01-08-2017, 12:14 PM   #7 (permalink)
WiSH2oo0's Avatar
Engine: Hemi 5.7
Default
I would like a 6" over the 4" but I was just relaying the response from Superlift "We wouldn't recommend anything higher than our 4" lift kit with adjustable lower control arms".
I've been searching google to no end and have only found maybe a half dozen of 4TH Gen single cab short bed lifted trucks on the forum boards. The two I seen on another board had 6" RCX lift kits.
Old 01-08-2017, 01:04 PM   #8 (permalink)
Dantheman's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
What about getting a driveshaft from a quad cab and swapping it in?
__________________
Old 01-09-2017, 08:50 AM   #9 (permalink)
WiSH2oo0's Avatar
Engine: Hemi 5.7
Default
After some further reading on the Spohn Performance website. I think Superlift misspoke or I heard him wrong on the phone. But I think they meant I would need adjustable upper control arms to adjust for rear pinion angle.
Old 01-10-2017, 09:04 PM   #10 (permalink)
57buick's Avatar
Ram Year: 2015
Engine: 6.7L diesel
Default
Mine is a 2015 2500 diesel but I used a 6" ZONE lift and it drives great. I didn't install the optional tranny indexing kit either. Didn't need it
__________________
2015 Ram 2500 Cummins Diesel w\37" on 20's 6" Zone Offroad Lift
57buick is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2017 2500 4x4 Laramie Short Box 6.4L HEMI 67Guzzler Member Trucks 56 04-04-2017 11:28 AM
2017 6.4L 2500 4x4 Larmie Short Box on Order. 67Guzzler Introduction 28 12-28-2016 11:55 AM
Lift on 2015 ram 2500 bighorn crew cab short bed Biggun Lifted 0 03-24-2016 08:24 PM
Standard Cab Lift? Kapt Lifted 5 12-18-2015 02:52 PM
2" Body Lift Standard Tranny?? MvZiC MaN Lifted 8 09-04-2012 06:50 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
