Next step after 5100 level?
Mbrigh3
IG: Stormtrooper_5.7
MD
That is a damn nice looking truck! I personally love the stance of it! What is your setup as far as tire size?
im curious about those tires as well!
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
...Will a set of 295 60 R20 Cooper AT3 fit without trimming? or down size to 305 55 R20? they will be mounted on a set of FUEL Mavericks 20X10 -24.
Anthony.
I ran this tire size (Nitto TG2) and these Mavericks but at 20x9 + 1 on Billsteins set at 2.8 and they rubbed at full turn . I since lifted to 4" Zone, dropped the Billies to 2.1, increased my tire size to 35x12.5x20 and went with the Fuel Mavericks 20x10-24 (sold my 20x9s and 305/55/20s to a buddy here in Ramforum).
First pic is stock and then Billies at 2.8 with 305/55/20s, and 2nd pic is now.
Hope this helps. Good luck!
sunkiz
Thanks for the reply, when you say rub, At inside or outside? If it’s outside with only a 9” rim, and +1 offset. No doubt it will rub with 10” -24 and blistering @ 2.1. Humm, I might have to down size my tire purchasing decision. Anyone else want to chime in? Killer truck btw
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
I did some trimming to the fender liner and that solved the problem. It did not rub the bender or interfere with the hub, etc. Mostly cosmetic.
sunkiz
Thanks, after I read your post, I just ordered a set of Cooper ATP 275 65 R20 just to play safe. (Best Value AT tires IMHO) I am sure I can fit a set of 35X12.5 R20 with some triming, but I dont want the tires to stick out too much only with a 2.1 Leveling Steins. These has the same width as my factory tires and only 1" larger so I wont lose any MPG!
Once I have my 6" lift in sometime next year, I will go "ball to the wall" possibly 37X13 R20 with wheel well flares.
Now I need to sell my 5 Nitto Terra 34X11.5X20s. (295X60R20)
Will post picts once they are mounted.
sunkiz
Bilstein at 2.1, Fuel Mavericks 20X10 -24, New Mevotech UCAs, Cooper 275/65R20 ATPs.
sunkiz
Here are some pictures, trying to rotate them correctly for posting.
sunkiz
And a few more pics. enjoy, I think they fill the leveled wheel wells quite nicely!
