Dryates
Installed my bils at 2.8 and installed mevo UCAs today, saved myself 500 dollars for install. Did not hear any clunking when driving, and everything feels ok. Also they drive alot smoother than with the what im assuming was a 1.5 spacer, as I gained an inch in the front. Please check these torque specs, im sure theyre correct but i wanna be double sure.
UCA nuts-120 ft lbs
Upper Ball joint nut-70 ft lbs
Strut bolt lower-100 ft lbs
strut upper nuts-40 ft lbs
caliper bolts-130 ft lbs
Tie rod end nut-55 ft lbs
Sway link upper nut-27 ft lbs
and I did the lug nuts 130-140 ft lbs, it was dark at this point, so i wont have pics till tomorrow, front now sits at 39 1/4.
UCA nuts-120 ft lbs
