Hi new to the forum. I've done a lot of research on leveling my 2014 ram 1500 4x4 regular cab and chose to go the bilstein route paired with a set of 285 65 r20 BFG ko2's. im in the middle of my install and I've been following this detailed YouTube video https://m.youtube.com/watch?feature=youtu.be&v=GpLJIln6VBA
However when I went to reinstall my sway bar link it wasn't getting tight so I removed the nut to find that the threads were stripped. I thought maybe I over tightened it or something was bound up, so I drove across town to O Riley's and picked up a replacement and was very careful when installing it. I jacked the lower control arm got it lined up. This time worked the bottom bolt and top bolt a little at a time however when I went to do my final torque which from what I have found is supposed to be 27 ft lbs I never got there I stripped out my second link.... I'm frustrated and hope someone may have an idea or suggestion as to what I'm doing wrong before I try again in the morning.
Thanks, Matt
Thanks, Matt
