well after writing 3 bad reviews on the rcx face book page i finally got there attention. after a few e-mails they admitted there was a problem and want to make me some coil spacers for the bottom to fit the bend. i am totally against running spacers top and bottom but im willing to prove they wont work and are unsafe.
I finally took it into my own hands to make it right again and did some simple math. When the truck rolls of the factory floor the axle sits plumb (perfectly vertical) and there kit comes with a upper arm that is 1/2 longer then stock. (stock is 16.5 theres is 17) That will push the top of the axle towards the rear of the truck. The axle arms are 5 1/2 inches apart top and bottom so in 5 1/2 inches it is pushing the axle out of plumb by almost 12.5 degrees. The rear coil spacer is 4 1/2 inches adding 4 1/2 of lift the the rear. The drive shaft is 41" (regular cab short bed) and we will round up to 3.5 feet for simplicity. When adding 4 1/2 of lift it will change the drive shaft angle 6 degrees. (this is the most it will change because regular cab short bed will have the shortest drive shaft) so Rcx is over compensate's by almost 6.5 inches with there upper arm and making the coil spring sit out of plumb by almost 12.5 degrees causing the big bend in the coil that we are all seeing.
