Rcx Lift 2013 ram 1500 4x4
Monster_88
I just purchased a rcx lift and it came with rear coil spacers and im putting bilsteins 5100s in the front maxed out, how can I level it out with the bilsteins maxed out
BigSexyBlue05
2012 dodge ram quad express
Maxing out the bilsteins is leveling it out
mattman_13
It'll be nose high. With the new Rcx kit you won't 've able to get as much lift as the older. Older came with springs we are able to add spacers. Now the lift being achieved by spacers it sucks.
Maybe order rear lift springs from another kit.
Shawn226
Mercer County, Pennsylvania
3.0L EcoDiesel
someone informed me to look for super lift or maxtrac 2 inch lifted springs to swap out with the stock springs.
M
Monster_88
I installed my lift and there is about 2" difference in the front the rear is higher its a rcx6" after installing it there was about looks like 2 spacers but there was no thing on the instructions to install them and it wasnt on the part list in the instructions
M
Monster_88
here are the pictures
straightravage
Did you figure out what that spacer was for??
I am expecting my lift to be here in two days and I am trying to find all and any issues that I might have during my install.
Thanks
lowone01
hemi
Those look like the pre-loaded spacer for the front. They started sending the 4in top spacer with the 6in lift and added the 2in pre-loaded spacer. now you have to take your strut apart and put them on top of the spring then put it back together that's how they are getting the 6in lift in the front now. But I don't know the reason behind it. Maybe its not causing as munch bind so the ball joint wont pop out on the 2013-14 rams. If you look on there web site all they are doing is putting there 2.5 level with there 4in kit and calling it 6in now.
moparmorris
Do you have any pics of your truck?
straightravage
The new instructions on their website show it at step 41, seems simple.
I start my lift first thing in the morning.
Does anyone know if you have to torque EVERY nut and bolt on this isntall?
The instructions break down all the torques, but I do not know if the **MM torque table is for the wrench or actual nut size?
MiRamDriver
I torqued all of my stuff for my install. I know that my Zone instructions had torque for everything.
iam_canadian22
northern ontario
usually torque tables are for the bolt size, not wrench or nut/head but physical bolt diameter
