Which Rear Coil Spring Spcers Should I buy?
Pinnacleplumbing1
Dedham, Ma
Hey guys.... I am looking to buy some 1" rear coil spring spacers... Not sure which ones I should buy for my 16' ram 1500 4x4... There are the cheap ones on eBay for about $30-$50 or so... Then there are the TGC's for around $70 or so... There are plenty of other brands out there as well... Do you guys recommend one over the other?... Poly vs steel? (Im leaning towards steel)... Let me know what you guys think...thanks!!
Gary2
S Jersey
I used a pair of TGC 3/4" poly and then switched to a 1" set of Jeep wrangler TJ poly spacers ( same as the Ram spacers) .
Maxtrac Suspension
Anaheim, CA
4.7L V8
We offer a 1.5" rear spacer for the Ram 1500's. If you Google search "Maxtrac 1628" you will get pages of results with websites to get pricing and purchase from. Just another option I thought I would throw out there for ya.
Scgirardi
With the 1.5 wouldn't you need longer shocks?
Pinnacleplumbing1
Pinnacleplumbing1
Dedham, Ma
I see you guys offer both poly and aluminum spacers... Is one better than the other... Or are there pro's/cons to each? I'm nervous about going up to the 1.5" spacers for running the risk of having to replace the rear shocks...my mods budget will be shot after buying an ARE cap, front bils, rear spacers, and MT tires.... I know the rear shocks aren't terribly expensive... Just trying to not spend more money if I don't have to!!!
Maxtrac Suspension
Anaheim, CA
4.7L V8
We only offer the aluminum spacers we do not make any poly spacers. if you aren't comfortable with it I would say just go with a smaller spacer or wait until you can afford shocks. I want you to do it the right way.
