I want to remove a BDS 4in lift. I see from the instructions that install required trimming the rear control arm pocket. I'm not a mechanic and am unsure what this means in terms of removing the lift or even what exactly this is...I believe that I have to either find this piece or fab a new one and weld back on.
I am also assuming that as long as I have all the stock parts, this is the only real issue (I still have all stock parts).
Few questions:
1. What are my options with the trimming of the control arm pocket? Finding the old cut out peice or fabricating a new one and welding back on?
2. Is this the only issue? I believe that everything else is bolt on and can easily be brought back to stock with the stock parts
3. Will I see any impact to stock performance?
4. What are my options to return to stock or at a minimum, closer to stock height?
Thanks for the help!
Few questions:
