Replacing rear springs, have a few questions.
ders808
I have a 4" Rough Country lift on a 2010 Ram 1500 QC and it's not leveled which irritates me. I want to replace the rear coils to something that would make it level (Even a slight squat won't be bad). I don't know where to start and which parts to buy to replace the rear springs, or if this will even give me the desired outcome. So, I'm asking you, RamForum, what do I need to do?
Thanks
PS: Pics can be provided if needed.
D
ders808
I'm not sure what they are, I believe they may be stock(I looked and it had a Chrysler tag on it). But I'm not looking to raise the front any more, I want to keep it where it sits so there isn't a lot of space in the wheel-wells.
smoothee
St. John's, NL
Weird, that kit should've had you sitting pretty much level. So are you wanting to lower or raise the rear?
AustinB
Banned
San Diego, Left Coast
Probably going to have to go through zone or bds... And if you have the rear spacer version... Maybe can just remove it and try that.
Stand by for an rcx expert to confirm.
IMO
smoothee
St. John's, NL
As AB said, your best bet would be to go with a smaller spacer in the back (I'm assuming the 2" spacer is what you have currently).
D
ders808
There isn't a spacer in the rear, coil goes from the axle to the top enclosure.
I'll edit in pictures in just a moment.
EDIT:
Here are the pictures: http://imgur.com/a/llHvF
You can see the previous owner once had blocks, but decided to use something else perhaps?
AustinB
Banned
Rcx used to come with springs (don't know what size, maybe call them and ask) but now they just have spacers for the rear.
Once you figure out how much lift those provide, you can start searching for a smaller size. Worst case , get a set of stock springs off someone ( a lot of guys have them laying around, including me).. If they're too short, you can add a spacer to your desired height.
IMO
smoothee
St. John's, NL
EDIT:
Here are the pictures: Imgur: The most awesome images on the Internet
Ah ok, I wasn't sure what year RC started going with spacers (my 11 kit had spacers).
So I'd do what Austin said.
PassivAggressor
Unless you really want to save money and just chop a coil or so off...
D
ders808
IMO
would you happen to know where I could buy a 3" Rear coil set?
AustinB
Banned
