NovaNewfie
- Nov 9, 2014
- 5
- 0
- Rural Nova Scotia Canada
- 2011
- Hemi 5.7
Hi All,
I'm new to this forum. I have a 2011 Ram 1500 Laramie 4x4. I recently purchased a rough country 2.5" lift level kit and a set of Airlift 1000 rear bags.
I installed them last night. Gained 3" in front and 2" in rear with 35psi in the bags. My question is, when you install the bags you need to run the hose up through the top of the spring bucket. On this level kit there is a plate that goes on top to hold the rear coil spring spacer. I left this out so I could run the hose up through the spacer. Has anyone else done this? Any ill effects? If you found a different way to route line and use all parts please advise?
Thanks
Thanks
