I recently purchased this leveling kit. I had a few questions I was hoping you guys might be able to assist with. After reading your posts, it seems I'm even a little more confused. I just bought this basic kit to raise the front end level with the back. It's the 2.5IN Dodge Leveling lift kit from Rough Country. I will post link below. I was wondering how hard the install was, does it require an alignment after and is there anything else needed besides what's included in this kit because it seems you guys went above and beyond. Also it says I can put up to 33x12.50 tires once this is installed. I don't need spacers to accomodate the tires do I? Thanks for any insight you might have.
