mselph544
So that rear end squeak came back. Found the issue.
If anyone has issues with aftermarket shocks squeaking. Check this out.
This bump stop plate near the eye on the shock that bolts at the top is what was squeaking on my truck. (See picture)
Now, it seensures when the shop torqued down the bolt, it bent the bracket in a bit and made it rub metal to metal. What I did was take the top shocl bolt off. Straightened the bracket back and bolted everything back up. Torqued the upper to 40lbs. No more squeak.
