slight clunk in the front end.
stevens
2015 Dodge Ram sport 4x4 crew
any ideas what it could possibly be? im going to check & lift the truck up and see if theres any tire play, thought id post here first, it alost sounds like its coming from underneath dead center in the middle...front end* maybe ball joint? anyways post here if you got an idea! like i said its just a small clunk sound over a bump, not all the time.
Ratket
Arizona-
What are ur truck specs? What lift/style- don't spare any details-
stevens
stevens
omg so sorry, guess my edit didnt go through, 6" zone suspension, bilstien adjustables up front to level.
ram 1500 2015. with 37's
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
swaybar endlinks?
02ramboi
live oak florida
4.7 v8
Possibly your all joints need tightening
stevens
stevens
hmm okay im going to take a look at all that.
02ramboi
live oak florida
4.7 v8
After I installed my lift I hear the same thing mostly when turning and another member told me sometimes the ball joints will be loose I haven't had a chance to tighten but I'm almost certain that is it.
stevens
stevens
well i kinda heard something today...the clunk..again....when ever i push down on my break pedal and put it right to the floor i hear the clunk sound....same sound when ever i hit a bump ...not all the time but it sounds similar? that's odd lol i don't know what to do there...should i check underneath the engine bay? or by my break pedal.
02ramboi
live oak florida
4.7 v8
I might be wrong but I don't think your brake pedal should or can be making any clunking noises
stevens
stevens
it's odd....i don't know why its clunking..something lose? im not sure
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
I have a zone 6” lift and I had a clunking sound when I hit bumps, potholes, or anything larger than a standard bump. Happened at all speeds and I couldn’t figure it out so I began going over every bolt with torque specs. Replaced sway bar end links and finally started going back through the lift directions. Turns out the washers on top of the strut tower that hold in the strut top spacer were not installed. I put washers in and the clunk went away
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Did you ever figure out what it was?
My next advice would to be tighten your cab bolts. The ones that hold the body to the frame. Starting in the front working your way towards the back
