Steering clunk after 6" lift
Cheyenne14
As the title says I have a clunk noise after installing my zone 6" lift. Its only when I am parking or turning around at slow speeds. When I turn the wheel either way and then turn it back something in the steering clunks pretty loudly. Anyone else have this?
1500ram12
5.9L Cummins
Check the track bar and if there is a drop bracket check the bolts for that
Sent from my VS985 4G using Tapatalk
JCARTER7
NJ
Sound is coming from the front end
1500ram12
5.9L Cummins
I was thinking of a 2500/3500 sorry. Check anything connected to the steering. Something isn't tight
RAMYOU
i know an old escalade that exactly did that. turned out it was worn /in ur case maybe lose/ lower A arm joint.
Cheyenne14
Cheyenne14
Thanks for the reply. Its about that time I go get everything check and retightened so ill have them look at that
RamminJammin
Try your sway bar I know it sounds crazy but depending on how your are laying under your truck I believe the passenger side is reverse threaded. At least mine seemed that way and it was loose after my lift. I snugged it up and my clunk sound went away. Also you could jack your truck and shake all suspension components. You can even go as far a gopro zip tied to your suspension. Just ideas for you.
Cheyenne14
Cheyenne14
I have a feeling the sway bar is the cause. Thanks for the help!
Cheyenne14
Cheyenne14
I do too. Bump
Hey JCAR have you resolved this problem? I have benign living with it even though I have been under my truck a dozen times in the last couple months.
Im going to finally check it out tomorrow. Figured I'd pick your brain.
DohCanadian
Saskatchewan, Canada
I have this same clunk with a 6" RCX lift. From all the reading most do say sway bar, I haven't got around to checking mine either though.
