Still debating on level or lift.
jknappen
Kentucky
Currently i have sitting in the box a HBS 2 inch level spacer kit. Would still need to get some mevotechs. Want to get opinions here should i level it with that kit, sell the spacers and get bilsteins and set them at 2.1. Get a ready lift kit from rancho. If i get the bils then i know i can still get a lift kit if i want to down the road.
I also would like to get new wheels and tires but not sure if i want to keep the stockers for now. I have factory 20s now. With just a level kit or bils can i still get a 20x10 with a -24 offset wheel with 35x12.5 with no rubbing? Or should i just run the stockers for now?
RollinOnXDs
Go with the bilsteins. Money says you WILL want to lift it down the road. It's never big enough
Klaus96
Illinois
2014 2500 CC Laramie 4x4
Only spacer worth a look is the maxtrac 2 piece spacer. It's easy on the ball joints and I run it. But only cuz the bils were on backorder for months when I was buying.
firemedic10584
Central Fl
I'm in the same boat! Just got a new '15 2500 4wd and it sits pretty high stock...I definitely want to level it, but If I could find a 4" / 1" suspension kit, I'd much rather go with that. Just can't find anything so far :(
TheFactor
Oregon
Can the bils still work running the same ones on a lifted that were made for just a level ? You'd think they'd be to short ??
chipmaker
AZ
You can start with Bils then keep them on the bigger lift. I was going to do that until I saw that with bils and 35s, my family struggles to get in. Bummer, but leaves more HD money...
jknappen
jknappen
Kentucky
What tires do you have?
gassersarentdead
ohio
How do they struggle to get in? I have bilsteins maxed, 6"suspension, and 37s. My 8 and 10 yr old have no problem with steps.
Rzrman328
The treeline
Mine are 5 and 7 with no side steps.
I just get a good running start and chuck'em in there.
