Stock tradesman Leveling
sticknstring
Can I put a 2" leveling spacers up front without having to put on longer shocks?
2017 2500 tradesman w/ 5.7 4x4
Juvenator93
I wouldn't. I ran a 2 1/2" RCX level that came with shock extensions.b01f1aa935ac1fdbbca1a37251a081f5.jpg425805e427a09b5276b8d2c88aadf8cc.jpg On harder off road use the shocks would still max out. Ran the setup for about 6mo then upgraded to a Thuren kit d150db774bed17bded864b67c141fb85.jpg
Juvenator93
MADDOG
Not RamForum Staff
I used a Tuff Country 32909 the shock relocation bracket on two 2500 trucks. Works great!
jcagle
I did not install new shocks or shock extenders and have not had any problems.
Sent from my SM-G930R4 using Tapatalk
Ratket
Arizona-
You put a spacer in with stock shocks and no shock extensions? And have no problems? I guess if the truck suspension doesn't ever really travel you may not. If you are going to off road I highly suggest you either A run the spacer and the extensions or B get a full spring/ shock replacement like the Thuren Kit.
jcagle
Yes no problems at all, but like you said I don't do any off roading. At most I take it on the beach
DannyMK2
Long Island, NY
2015 Power Wagon
you run the risk of overextending the stock shock without the extenders. if the truck never leaves the payment its probably not an issue. shock extenders are cheap, at the very least i would run them.
S
sticknstring
Sorry fellas posted this before I did much looking at leveling kits.
I ended up ordering the Rough Country 2.5" that comes with the mounts for stock shocks
Juvenator93
Juvenator93 what is your wheel/tire combo? Those look really good!
17x9 +20 Fuel Boost wheels and 35x12.5R17 BFG KO2s. Ran the kit you ordered for 6mo and sold it to my coworker. He currently has had it installed for about a month. a12e0cf9fc8840010337ab20539de7b8.jpgb48d464f25b1354e68d0b05705a805fb.jpg
S
sticknstring
So the 35x12.50's will fit with just the 2.5" leveling kit on the front?
Ratket
Arizona-
Easily - with the Carli lvling kit u can run 37"s on factory 20"s . Just make sure u get the correct wheel with proper Back spacing.
S
sticknstring
Thanks [emoji1303]
Juvenator93
Oh yeah, I have plenty room for my 35s, could clear 37s with my current setup
SwollenMonkey16
Texas
You'll love the RC level kit. It makes a huge difference. On the appearance of your truck
S
sticknstring
Waiting for FedEx to drop off the 2.5" Rough Country leveling kit.
S
sticknstring
After you put your RCX kit on did you get an alignment? The instructions said to get one and mine seems just a little off now. Just wondering if you had the same thing.
Juvenator93
Yup, needs an alignment after install
S
sticknstring
This is what my springs look like after the install.
Drivers side, then passenger side.
I have NOT gotten an alignment yet, trying to get it in next week.
Is this normal? And will the alignment straighten the springs out?
Or did I do something wrong?
