Superlift 4" Install Advice?
Coop427
In Sane
14 Ram 1500 Sport
I'm in the midst of installing a 4" Superlift on my 2014 Sport 1500. I've removed the LCA's and struts. My plan is to set the Bilsteins to 2.1 & run 35" Toyo AT II's. Am I on the right path? Any advice on the install? Thanks & Merry Christmas!
Jershipe
Monroe Michigan
I have the rcx 4 inch with bilstiens at 1.4. I had to run a spring spacer in the rear. I was nose high a little. But rcx kit only lifts the rear 2.5 inches
Juvenator93
I set my 4" Superlift and Bils at 1.4 and 35s6873b35ad14253f6cd0dcc18fb0e8443.jpg
Ferro
On my Zone 4" lift with 35s. I have 3" coil springs in the back. And I have the Bils set at 1.4.
Coop427
Coop427
In Sane
14 Ram 1500 Sport
Thanks. Got the differential out, Crossmembers cut and drop downs bolted on today. Now to pop the cv axles out, put the differential back in and bolt in the new crossmembers. Slow going, never did this before and afraid of screwing it up.
6.7CumminsDrvr
The Dude abides………
Georgia
Mine are set @.7" but I'm gonna bump them to 1.4" when I find some time.
Coop427
Coop427
In Sane
14 Ram 1500 Sport
Set the Bils to 1.4, the front is done. Had to install the differential twice since Superlift can't write instructions clearly! Hitting the rear half in the morning.
mpittman
Indiana
2015 Big Horn Crew Cab
I'm getting a BDS 4" installed next week. My install shop lifts over 40 RAM's a year for 3 dealerships. He says Bilsteins at 1.4" is the most common setup for this type of job.
Coop427
Coop427
In Sane
14 Ram 1500 Sport
picture.php
Thanks. All done, waiting on 35's and an alignment now. I talked to Superlift today, they said 1.4 seemed to sit best. I won't know til it all settles, it was 6" in the front when I set it back in its wheels. The top bolt for the shock was the worst, I used a vice grip.
mpittman
Indiana
picture.php
looks badass... I hope mine looks that good when I get my BDS 4" with Bils installed next week.
Ferro
Look good. Can't believe how much better these trucks look lifted.
Coop427
Coop427
In Sane
14 Ram 1500 Sport
I have before measurements & roughly measured after when I set it back on its wheels. It took the front end from 36.5 "to 42.5" and took the rear from 39" to 42.75". But the front end needs to settle in yet.
Thanks for the compliments, can't wait for the Toyo AT II's to come next week & alignment.
VLG6963
