Supreme Suspensions?
carcandy
South Florida
2018 Big Horn cc 4x4
6.7 CTD
Brand new member and Dodge owner here. I've been poking around looking at leveling kits and came across this on ebay:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Has anyone had experience with this brand? I'm looking at using this in the front and possibly a 1-1.5" in the rear. This would be going on a 2011 2wd.
photo.php
RamFan2
They look about the same as the ones I have, (daystar 1.5" coil spacers). I've got a 2011 2wd also, and actually was trying to put them on last night, couldn't do it though. I'm probably not typical though, a lot go guys here have done it.
quietpeen
2021 TRX
Hellcat
welcome to RF. I have no experience with them. I have read that the poly spacers can compress over time
WhiteExpress
Midland, TX
In a word, No.
The poly might deflect ~1/8" over 100k miles. It won't, however, slap or clatter when you hit a pothole and you slam to full droop. It will also help absorb some of the harshness of impacts.
I've come to understand that anything over a 2" spacer is too much for the Gen IV front suspensions. I don't buy the 94-11 listing on the last part, but maybe I'm wrong.
ivan
South Texas: McAllen area.
Hey do your album pictures reflect the leveling 1.5" leveling kit? The angle of the pic and the slope of the drive might lead me to see it incorrectly. I want to order my leveling kit soon and even though I can't find the Daystar 2.5" for some reason, I do think I'll go with the supreme suspension. Theyre service seems really good on paper.
bloombloom88
Plano, Texas
Supreme suspension offers level kits up to 3 inches. I'm looking at a 2.5 inch kit, make sure it comes with shock extensions or replace your front shocks with longer ones so you keep your ride as smooth as possible.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I would rather use a steel or aluminum spacer over a poly
My buddies BDS poly spacer cracked on his truck after he had laughed at the hell bent steel spacers
There is a rubber isolator that goes between the spring and spring mount in 2500s I would think there are on yours as well
30k miles with a spacer and I've never heard a single notice dome on them, just other front end parts lol
