Pinnacleplumbing1
Hey guys... I had bilsteins 5100's set @ 2.8 put on about 1000 miles ago with 1.5" spacers in the rear... started getting a little squeak out of the front end about a week or so ago... I noticed the boot of the ball joint on the passenger side is slightly torn... so I'm pretty sure I need to upgrade to mevotechs ...I took the truck to my mechanic to confirm and he did... but he also said he is seeing a lot of play in the sway bar linkage and I should upgrade those while we are at it... just wanted to get your thoughts.... haven't read much on here about sway bar link issues... is this common?... what brands links should I buy?... thanks for any input!!!
