Thuren/King on '17 1500
ff36buell
Wilmington, MA
Posted in the introductions earlier today. Figured I would come over here and share. 2017 Crew 1500 SLT with Thuren Stg.2 Kings. After talking to Don I have to say I cannot wait to see what new parts he develops for the 1/2 tons. I did add a .75 inch spacer to the rear from Top Gun Customz because I was sitting a little nose high with a full load.
Love the ride and after driving down and back to the Outer Banks in NC, I can say this suspension soaks up both the highway and unfinished roads with ease and comfort.
Nick
TomT
SoCal/OC
Having my Stage 3 kit installed on Saturday. I can't wait.
:favorites13:
SJP_1809
GA
Looks good!! How much did those coil overs raise the front? And are those 35's?
F
ff36buell
Wilmington, MA
Thanks, I am still planning the rest since toys are never really finished.
Ttubbiola: your going to love it, a little strange at first because its smoother/softer and more responsive at the same time. What wheels/tires are you going with?
SJP_1809: I believe I am right at 2" up front. Obviously stock 20" wheels, no spacers and 295/65r20 Toyo AT2 extremes. I think Toyo says its approx. a 35x11.50.
Nick
wisey113
Charleston, SC
Do you happen to know if Thuren will make these in custom lengths? I have a 4" lift, and right now I've been looking at getting the Kings through Filthy Motorsports, but I'd really like the Thuren valving / tune.
TomT
SoCal/OC
Nick
I already have the setup with Bilsteins at all four corners. I'd shouldn't look all that different although I will take measurements before and after just for fun.
TomT
SoCal/OC
Give Don a call or even better drop them an email or Facebook message. They're usually too busy to answer right when you call but will normally return messages within a day.
F
ff36buell
Wilmington, MA
Ttubbiola is right, send them an email. Don was VERY good with any questions I had.
Nick
UnsatFC
Active duty NAVY
New Jersey
That is awesome set up. Seeing this makes me wish I had more money
Nick
TomT
SoCal/OC
So far I really like the ride. I had the truck aligned but it needs to go back as it pulls to the right a bit. I kind of want to remove the fender liners and show them off.
F
ff36buell
Wilmington, MA
I wish that was possible up here in New England. I also wish I had more places to play with it.
Nick
AzCats
Portland OR
2014 1500 CC Laramie
How have the king shocks been ? Are they still comfortable?
TomT
SoCal/OC
A little stiff at low speeds but get moving a little and everything just smooths right out.
TomT
SoCal/OC
No idea, it’s pouring here and I’m an old fat guy. :D
crazykid1994
Florida
Those would be beneficial to me if I can set them over the 2.5”. Closer to 3”. Even 2.75 would be fine. Stuck between thuren Kings and bilstein 6112 whenever I blow out my bilstein 5100s
TomT
SoCal/OC
Found some photos from my install. You might be able to read the numbers on one of them.
ram1500rsm
Trabuco Canyon, CA
Ty Tom, it's in the last pic, i think you have same springs i have
3.75 =spring diameter
14 =14" free length
500 =500 lbs/inc spring rate
If you ever consider going up, i have details of what tools you'll need and how many turns you'll need depending on how much lift you want to have in my build thread.
Thank you one more time.
TomT
SoCal/OC
I wanted the ride to not be too stiff but still hold up when I decided to get stupid out in the desert.
