Suspension is not a place to cut corners because it could be a safety issue, alot of us have the zone arms and love them. I personally have never heard anything negative about zone.
I'm with you. What's $100 when you have a $50,000 truck. Pay now or pay later that's my motto.
It looks like there might be another option for UCA'S. I haven't done much research on these, but they look good. And they're only about $60 more than Zone. 3/4" solid steel, fully tig welded,1" spherical bearing, lifetime warranty, all sound good to me!
It does not say if they will work for a leveling kit, or if you need to have a 4" minimum lift. Also you have to drill out the stock, tapered spindle bolt to fit the bigger, straight bolt.
09+ Ram Upper Arms For Lifted Trucks
Zone uses a strong and replaceable moog ball joint, you really can't find a better ball joint than that.
There are alot of uca options for 09 and up Rams but I wouldn't buy in to all the hype. You can spend 700 on totally chaos , fabtech or other brand and have a squeaky unibal. Zone is the best bang for your buck on the market in my opinion.
