69GWC
Power Wagon
- Oct 1, 2015
- 5,387
- 6,952
- Spring hill, Kansas
- 2022 Power Wagon
- 6.4 Hemi, 8sp
looks good, what are you setting at 2.1? also what size are your tires .
Thanks
Thanks
Thanks
ALL DONE!!!
Looks fantastic.
Pretty rough ride from what i remembered and kinda clunky over frost heaves, but assume its just settling. Took it around the block and then re checked all the torque setting and all is where it should be and the strut tower is facing the right direction. Gonna get an alignment and if it still have problems i will take it back down.
Thanks for the help fellas!!
I did the work on a very slightly not-flat ground so my measurements are kinda funky, but did the measurements in the same spot so it should all be relative (and 3/4 tank of gas)
RF: 37.0
LF 37 1/8
LR: 40 3/16
RR: 39 3/4
NEW:
RF: 39 1/4
LF: 39 1/4
got tired and wanted a beer so i did not measure the rears lol
Here is a before and after, lighting is kinda odd today and the "after" pic is kinda dark:
I had the same issue when I did mine Thursday, we just pressed forward without worrying about the pins. Didn't have any issues.
Looks good to me. If it was the original shocks, it will probably be more rough, as you know. Mine rides like a champ after a few days. Keeps us posted
Figured out my problem. Turns out the directions I was using had the incorrect order for the hardware. I have the washer just below the nut, rather than under the top plate as it should. Fml
Well, let this be a lesson to all those future DIY installers: cross check directions.
(Dammit!!!!!!!)
Sent via telepathy
You are not the first one to do that and I'm sure you won't be the last.
The bright side of this is that it should go rather quickly now that you know what to do and expect.Agreed. Just really bummed as after seeing how it turned out i was REALLY excited to get it aligned and start driving it again. I guess i can wait another week, but its just staring me in the face!
