bigkevfann
I just got new wheels with the appropriate offset and had them do 37x13.5x20 nitto trail grapplers. Even with the 6" lift, the tires are STUFFED and don't allow for much travel. Discount said they will exchange for 35's if I want since they actually rub with the right movements. I do have all 4 bilsteins on the way. I understood that the rears were adjustable to an inch... but i was wrong. If I understand everything, my choices are to exchange for 35's and don't raise... or... set the bilsteins to the setting a little over an inch, but then need an option to bump the rear up an inch. I don't plan to mod gears or anything due to 37's. What are your recommendations. And if deciding to raise another inch or so, how do I raise the rear? I prefer to try and keep the inch rake because i am loaded down or trailering almost all the time.
