BSLugnut
- Dec 30, 2012
- 69
- 17
- Loudoun County, VA
- 2012
- Hemi 5.7
I recently installed Bils at 2.8 on my '12 RAM 1500 Laramie Crew Cab 4x4.
I like the ride, as the ride is not as harsh in the Laramie as it is in the Express, probably due to the weight difference between the vehicles.
After the alignment, my truck sets perfectly level front to back!
The challenge will be this fall, when I load the bed with hunting gear, a deer or two and or firewood. During the fall this truck sees fire roads, washed-out creek beds, public land access roads, and forestry roads.
I am considering the following options to mitigate my truck bulldogging with a 300-500lb load:
1" TGC Spacer - Welded Steel
1.5" MotoFab Spacer - CNC Billet Aluminum
ICON Rear Coil-Springs - 1.5" lift
TufTruck TTC-1223-V Coil Springs - OEM Height
Air Lift1000
TLC for Ram 1500 Coil-Spring
Any insight from your experiences will be appreciated!
Thank you in advance!
Air Lift1000
