I put the part numbers a few posts up:
Bilstein P/N 33-185569 w/superlift bushing kit P/N 77-80038 buy 2 of ea part number
They don't sell a direct replacement shock with bushings installed for our trucks, you'll have to buy the bushing kit from superlift directly for about $6 a set (1 set per shock so you need to buy qty2). The bushings aren't hard to swap on new shocks. The bushings are needed for our bolt size. I bought the shocks from summitracing but when/if you call superlift for the bushing kit ask for a price on the shocks too.
I am not familiar with RC shocks, you should call and ask them. On my Bils you notice my label is on top where you can read the text, mine are installed properly.
Does it matter which way I mount my Bilstein shocks?
Bilstein shocks often come with the same size mounting eyes on each end. We often get asked "Can I mount them with the shock boot up, does it matter which side is facing up?"
The majority of Bilstein shocks mount with the boot on the top of the shock. Bilstein does have some shocks that do have the boot on the bottom of the shock and the same size mounting eyes on each end. As a general rule with all Bilstein shocks, you should pay attention to the label. Bilstein tech advises that you should always mount your shocks so that the Bilstein logo is right-side up.
So, If you are not sure which way is up on your shocks or wonder if you can mount them either way, always look at the Bilstein logo. If it is upside down, so are your shocks!
