-12 vs -24 Wheel offset
Syntec
Eh?
H5.7
Close to pulling the trigger on 20" wheels, looking for feedback pics on -12 & -24 offset, want the setup to look aggressive and stick out a bit (will be adding fender flares down the road) -- however don't want it to be an overkill.
Post pics please :happy107:
2014greatwhite
Western mass
I have -24 wheels with 35x12.5x20 tires and smittybilt m1 fender flares on my truck. They stuck out about 2" out of the wheel well before the flares and now with the flares they are even with the edge of the flare. So I would say -24 sticks out about 2" and negative -12 would be around an inch.
quietpeen
2021 TRX
Hellcat
Here is my truck on 20x10 with -24 mm offset. Tires are 33x12.5. The tires stick about 3" from the front fender. Not as much at the rear
Before fender flares
After fender flares
Witch
Hemi 5.7 liter
I am not really up on this, but I think backspacing is in play as well
I just bought some wheels and and they offered the type I wanted in two options
-24 with 4.5" backspacing
-12 with 5" backspacing
I wish I could tell you what the difference is between the two and how backspacing affects the setback , but I just don't know
If they get here on time I will be mounting them on Friday, I will get a picture for you
QP: nice ride man
quietpeen
2021 TRX
Hellcat
Thank you witch
Back spacing correlates to offset(it's just two different measurements) -24 offset will stick out from the fender 1/2" further than the -12 offsett
R.L.K.
Bristol , Tn.
For anyone interested this is a fantastic explanation of offset & backspacing.
This is Brandonjanson's guide to Leveling in the 4th Gen Lifted stickies @ the top of the lifted section .
Just click the link and scroll down a bit to the correct area .
http://www.ramforum.com/showthread.php?p=1087056
Hope this helps !
quietpeen
2021 TRX
Hellcat
There is also good info stickied at the top of this section :happy107:
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
quietpeen pretty much hit the nail on the head. With 35x12.5's a 20x10 -24 offset will poke past the fenders by about 3". A 20x10 -12 offset will poke past the fender by about 2.5". If you have OEM fender flares you can subtract 1" off each of those measurements as they provide 1" of coverage.
S
Syntec
Eh?
H5.7
Very nice truck. What fender flares are those?
Might have to go with -12 offset as I wanted it to stick out little less
Wise
Harrison, Ohio
I regret not going with -24 instead of the -12. When I added the flares it looks a little sucked in, I'll post a picture when it's light out.
quietpeen
2021 TRX
Hellcat
they are oem 2500 fender flares. I'm contemplating getting new wheels and also thinking of -12 instead of -24
quietpeen
2021 TRX
Hellcat
what tires do you have? Bushwacker flares stick out far and without an aggressive or wide enough tire it could look a little tucked
S
Syntec
Eh?
H5.7
well damn I thought my decision was made :mad:
I am also wanting to put bushwackers on down the road
what tires are you running?
Wise
Harrison, Ohio
They're 33 KO2. Sorry about the **** photo I keep getting an error when I try to attach the images on the forum site.
quietpeen
2021 TRX
Hellcat
Wise. Are your wheels 9" wide or 10" wide?
Rzrman328
The treeline
I will agree with your assessment.
Although frowned upon by some.....Spacers would easily fix this problem.
Wise
Harrison, Ohio
I believe they are 10 inch wheels. Yea that is my plan, I just have to do some research first I've never used spacers.
BogsRam14
NJ
If you do a spacer get Bora....They are produced when you order from them.
