-24 or -44 offset on leveled?? w/PICS
mxblaster83
British Columbia, Canada
2014 Ram Sport
HEMI 5.7
i got a 2014 1500 sport ..right now i have 34"duratracs on stocks with 1.5" bora spacers and bushwacker pockets flares..
i want the fuel mavericks 20x10 with nitto trails 35 x12.50 x20 but not sure if i should go with -24 or -44...id like the wheels to stick out a tiny bit from the flares..
they still stick inside with the spacers which i will remove when i get rims.
Rzrman328
The treeline
-44 will stick out past the flares.
-24 might be real close with the flares.
Csanders1992
-44s will be 20x12s. They'll stick out a decent amount. You'll actually probably rub pretty badly with them
quietpeen
2021 TRX
Hellcat
With the higher offset and bigger tires you would have some rubbing with -24mm offset it might be as easy as trimming some plastic. I'm assuming for the -44 you mean 20x12's? I would say you would need more lift to fit those
Robocop_9
West Virginia
You'll need more lift in the front or you will rub. These are 20x10 with 33x12.50
quietpeen
2021 TRX
Hellcat
He has -24
Dryates
Texas
There's too many mixed reviews on this, some say you will rub, other that say they are actually running 20x12 -44 with 33x12.5 with just a level say they do not rub. This is all over customwheeloffset.com and I've have several running this combo who say they don't rub, but I have yet to have someone say they are running it and rub.
quietpeen
2021 TRX
Hellcat
33x12.5x20 with no rub and a level is not much of a worry on 20x12 with -44 offset, but he was asking about 35x12.5 and there will definitly be rubbing with only a level
Robocop_9
West Virginia
I have the motofab level with 33x12.50 on 20x10 with -24 offset and do not rub. A 35 might rub but the 33 do not. There are a ton of guys on here running every combo imaginable so someone will chime in and give specific on your setup
Dryates
Texas
My bad, I thought he was talking 33s, which is what I'm wanting to do
quietpeen
2021 TRX
Hellcat
No problem and from Whatcom have seen, with a level you should be good
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
i want 35 12.50 20.. with 20x10 -24 i have bilsteins @ 2.1 but changing to 2.8 due to sag,,, i have 34" duratracs with factory rims and bora 1.5 spacers with no rub
i dont care if there is a bit of rub on plastic as long as no rub on ucas
quietpeen
2021 TRX
Hellcat
You should be able to run them but might have some rubbing.
BIGDAWG2472
So with a 4 in lift, I will have no problems running a 35x12.50 -24
