Check your grounds for the resistors. I bet one came loose or fell off.swapped in the Laramie led's a while back with the retro shop harness and now I have hyperflashing and rear lamp out messages. any ideas why or how to fix this? thank you
If everything is connected nice and tight then try swapping the resistors and see if the problem follows the resistor. If so then you have a bad resistor.
Sent from my LGLS775 using Tapatalk
