2014 Ram tpms question
ctemp1
I am upgrading wheels and tires and need to know if tpms is a requirement
Meaning will I get a endless beeping from my dash if there are no tpms? Or is it just a warning light
Do I need Mopar branded tpms?
TIA
Steen
Weeki Wachee
2016 Big Horn Crew Cab 1500
TIA
Not sure about the 2014, but I can tell you about my 2016. You will need to have the TPMS sensors or you will get a long chime when you start the truck, and my speedometer switches over to the TPMS screen showing that it is not working. I have to use the arrow keys on steering wheel to get it back to the speedometer every time I start the truck. You don't need to have Mopar sensors, but a lot of dealerships won't even touch them if they're not. They say their scanners are only setup to read Mopars. I have an aftermarket set and was lucky that a Tire Kingdom was able to pick them up with their scanner. Topline Auto & Tire could not. I would order the Mopar sensors ahead of time and supply whoever is going to be mounting and balancing your tires to install them if you can.
C
ctemp1
Ok that sounds like they are a must. Problem is they are being shipped already mounted and balanced. Does anyone know if they can install tpms POST mount and balance without removing the tires?
Sowardcustoms
Burleson TX
5.7 E-Torque
Yes they just push the tire down on the machine enough to get to them then air it back up.
C
ctemp1
Thanks for the help guys
lasse452
