About to pull the trigger on wheels and tires...
pgr1990
pgr1990
3.0 EcoDiesel
The wheels came in today (5 days early!). Guy said they were supposed to be coming from California but apparently they must have found them closer. I’m having them installed tomorrow I’ll post some pics once they are on!
Two Dog
Ontario, Canada
2014 RAM RCSB Express
Looks great. The wheel and truck colours look very good together.
huntergreen
Looks like they were made for you truck.
Ramnewbie
Make sure you're lugs are torqued properly and check the centers of you're wheels periodically. I read somewhere on here where someone was having issues with Fuel wheels cracking around the lugs. Wheels look great though.
pgr1990
pgr1990
3.0 EcoDiesel
Only issue I’ve had is that the truck is vibrating like crazy between 60-65mph I’m guessing a balancing issue. Taking it back tomorrow to the tire shop to have them look into it.
pgr1990
pgr1990
3.0 EcoDiesel
Town fair has gone above and beyond I must say I’m completely satisfied with their service.
So the vibrating kept happening and they balanced them twice, then they ended up giving me general grabber AT2’s for $20 more a tire which I said is fine.
Kept vibrating despite the tire change. It’s only in the seats and floor board and not the steering wheel.
I called them again and they ordered me 4 new wheels and 4 new tires.
I couldn’t believe they went to those lengths to make sure I’m completely satisfied. Will update you guys when I get the new wheels and tires on!
Maligator
Hem 5.7
That was me that had the cracking in the stud holes to the hub bore. I had vibration issues in mine since the day I had them even with hub rings. My hubcentric XD Monsters with the same tires run smooth as glass
JB1
Houston, Texas
My hubcentric XD-832's roll smooth too
pgr1990
pgr1990
3.0 EcoDiesel
Do the fuels come with hub centric rings?
I ordered some custom aluminum hub centric rings 110.3 to 77.8 just to be safe when the new wheels come in
Maligator
Hem 5.7
Mine came with the plastic kind
pgr1990
pgr1990
3.0 EcoDiesel
Man you had a real bad experience. I sure hope when I get these new wheels on it fixes my issues. I really was in love with the style of the Fuels and love how they look just hate the bed vibrating the whole truck on the highway.
pgr1990
pgr1990
3.0 EcoDiesel
4 new wheels 4 new tires same exact issue.
This is really ******* me off now. It’s only happening through the pedal and seats and I can visibly see the bed shaking on the highway (worst at 65mph) low speeds is no issue at all and there’s no vibration or shaking through the steering wheel regardless if I’m on the highway or driving city streets.
Any advice on what to do?
billdozer79
Ohio
Subbed. I am having similar issues too. My steering wheel starts shaking around 65. Above 75 there's nothing.
Maligator
Hem 5.7
Some places I've read that your alignment should be checked after installing larger wheel/tire combos but this doesn't sound like an alignment issue. Did your new hub rings come in as well? I know alot of people run the plastic hub rings the wheels come with no issues but those custom fit ones may solve the problem. Mine had a quite a bit of clearance. Hope you get it figured out, this is one of those drive you up the wall issues especially when you drop 2k+ you want your stuff to run smooth
JB1
Houston, Texas
Is this with your hubcentric rings installed?
Did they also pull the disc brake lug rings?
https://tires.tirerack.com/m/tires/Pull%20Those%20Stud%20Clips
pgr1990
pgr1990
3.0 EcoDiesel
Yes, with the hub rings and I pulled all the brake rings myself when I replaced my brakes a couple months ago.
With the hub rings provided with the fuel wheels. I ordered custom aluminum hub rings exact spec. Hoping that might help. Are the fuel ones not exact?
pgr1990
pgr1990
3.0 EcoDiesel
Road force balance and put in the hub rings I ordered no difference, getting a full refund..
This is complete ********
