To get what you want, you need to drill a hole for second bulb in your reverse light section and to connect to the wires that to OEM turn light pin. But it is a headache...I've seen how was made on one truck.
That is what I had initially thought of and that is how importers generally do it in the UK. But the Ram uses the same light bulb and feed? for the brake and turn light. I think another box somewhere on the wiring that feeds the brake and turn signals must be fitted to somehow figure which pulse is a brake signal and which is a turn signal and filter each one in,... just thinking out aloud.
Check out Clive Sutton's RHD Ram 1500 conversion. Talk about meticulous.Yes you are right. They use some kind signal splitter that divides signal to stop and turn
