AMP research steps wireing
ivey_usmc
Austin ,TX
Sorry if this is not in the right section. I bought amp research steps and im about to install them on my 17 ram 1500. Question is the instructions call for me to run the command wires through the fire wall to under the dash and tap in there. Cant you just tap in under the fuse box to the same wires without going through the fire wall?
xrsman
Ontario
3.0 Ecodiesel
If you haven't already wired it, why don't you buy the plug and play? I didnt on my 2016, makes it so much easier!
Sent from my SM-G950W using Tapatalk
ivey_usmc
ivey_usmc
Austin ,TX
Already bought and everything is installed except for the command wires. Under the hood is for 2500's and up. Ill hard wire it in. Only 4 wires and I save $100
