Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Exterior
Exterior
Bed Organization - Phase One
This is a discussion on Bed Organization - Phase One within the Exterior forums, part of the 4th Gen : 2009 - Present category!
Just got my ratcheting cargo bar and adjustable organizer. Got a Sunferno bar. Very easy to ratchet and release. However ...
Like Tree3Likes
Sponsored By: BAK Factory Outlet
Reply
Old 08-08-2017, 03:50 PM   #1 (permalink)
wink's Avatar
Ram Year: 2017 1500 Sport RCSB
Engine: 5.7 Hemi
Default Bed Organization - Phase One
Got a Sunferno bar. Very easy to ratchet and release. However I need longer arms to hold both sides in place until the ratcheting. A common problem with all of them I'd assume. But it claims to hold up to 220 lbs. Might get a subdivider for it as well. The picture shows a slight bow in the bar. It you crank it really tight it'll do that. But I'd rather the bar bend than deform my bed. I found you don't have to make it very tight at all and it holds just as well.
The organizer is a Rola. It's got rigid walls and three fully adjustable dividers that attach top and bottom with wide Velcro strips. Also folds flat when not in use. I got it because of the height. It'll slide right under the tonneau canister. Without the dividers in there. I got the 38", but they make a 25" as well. One of each would cover the entire bed width. But the plans for it are to be under the canister, and to hold jumper cables, tools, flashlight, tie downs, etc.. Stuff I don't need to access all the time. The picture shows it in grocery mode. I'm gonna buy another, or something else for that duty.
Both seem to be of good quality. Only time will tell if they'll hold up. But they were reasonably priced.
wink
Power247 likes this.
Sponsored Ad
Register to remove this ad.
__________________
Wink's Hobby
wink is offline   Reply With Quote
Old 08-08-2017, 03:58 PM   #2 (permalink)
BiGMERF's Avatar
Ram Year: 2017 SLT 4x4
Engine: v6
Default
nice bro
wink likes this.
__________________
Im a struggling Mod-aholic
BiGMERF is offline   Reply With Quote
Old 08-09-2017, 11:32 AM   #3 (permalink)
Ram Year: 2012
Engine: 5.7 hemi
Default
your next step could be get a extend a bed thing and keep it folded in and that is a great cage to keep bags or soccer balls whatever in a area
trip1027 is offline   Reply With Quote
Old 08-09-2017, 11:33 AM   #4 (permalink)
Ram Year: 2012
Engine: 5.7 hemi
Default
here a pic
Old 08-09-2017, 10:43 PM   #5 (permalink)
wink's Avatar
Engine: 5.7 Hemi
Default
I looked at those. Hell I think I've looked at everything in the past couple of months. That's really major overkill for what I want | need, but thanks for the suggestion! I'll likely get another Rola, and have extra dividers from this one.
BTW, In the pic I have the cargo bar in front of the Rola, but doubt it's needed. The organizer has a rubber bottom so it probably sticks to the bed floor, and definitely sticks to my spray on liner. I tried pushing it across the bed empty, and it wouldn't budge. It's also wide enough that I doubt it'll tip over, but haven't tested that with any tall objects. But I've got tie-downs and the bar if needed.
Speaking of the bar. I was just about to pull the trigger on the Heininger bar, but read some comments that made me rethink it. True or not I don't know, but several people said you had to kind of estimate the width before ratcheting because it has a wide swing with one ratchet cycle. The Sunferno doesn't have that problem because it moves one notch per ratchet cycle. Just pull it apart to the actual width, then ratchet it once or twice, and done. I must say this seems much easier.
wink
__________________
Wink's Hobby
Old 08-09-2017, 10:46 PM   #6 (permalink)
Ram Year: 2012
Engine: 5.7 hemi
Default
I know what you mean I got two of those that I bought from Lowe's I use to use them before I made my flatbed
Old 08-10-2017, 09:43 PM   #7 (permalink)
DRkNESS's Avatar
Ram Year: 11
Engine: 5.7 with over 187,000 MILES
Default
Op do you have a link for that Sunferno bar as everytime I go to look it up, it comes up as a battery charger or Facebook automotive straps.
F.O.F
__________________
RetroShop led foglights, RetroShop headlights,oem Mopar grill, oem clearance lights,EGR roof spoiler,Undercover tonneau cover,DeeZee assist tailgate shock,Rigid bumper pod lights,Corsa 14405BLK Catback exhaust,Bilstein shocks,Toyo Open Country AT2 tires, Reproduction wheels, Pedal Commander,CompuStar remote start.
DRkNESS is offline   Reply With Quote
Old 08-10-2017, 11:21 PM   #8 (permalink)
wink's Avatar
Engine: 5.7 Hemi
Default
F.O.F
Here you go...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
wink
__________________
Wink's Hobby
Old 08-11-2017, 12:00 AM   #9 (permalink)
DRkNESS's Avatar
Ram Year: 11
Default
^^^ Thank you very much for taking time out and posting that link for me.
__________________
Old 08-11-2017, 01:52 AM   #10 (permalink)
wink's Avatar
Engine: 5.7 Hemi
Default
No prob!
wink
__________________
Wink's Hobby
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Garage Organization bianchina3 Garage 3 05-30-2014 06:43 PM
Phase One completed! Dante221 Lifted 16 05-22-2014 11:32 AM
Sub phase cableguy_hd Audio & Electronics 1 05-12-2014 08:47 AM
Adam's is now a one-polisher organization... AdamsPolishes Adam's Polishes 0 02-27-2014 10:20 AM
Phase 1 complete...pics!!! moodygunner Exterior 19 11-14-2011 01:40 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
