Best LED for fog lights
mpress2570
For my 2017 sport.
I'm not paying almost 600 dollars for the projector fog lamps. Also I have decided to go with LED fog lights since I have the auto high beams and the high beams get turned on and off a lot more frequently than if i did it manually and we all know on and off is bad for HID bulbs.
SO, what is the best LED fog light kit out there? I want 3000k for my fogs. Also do I need a canbus system or any special add ons for them to work on my truck like HIDs need?
Pics would be VERY appreciated. Thanks guys and/or gals.
Tyler Cooke
I got a set of the LED Fogs off of Jeremy at retroshop. They're great, I didn't think they'd be much brighter than the stock fogs, but they blew them out of the water.
OnSale
5th Gen Crew
Philadelphia, Pa
Those are only made for the 09-12 Rams at the moment. The 13+ Rams are shaped differently and vertical so these won't work on his 2017.
You should look into the Opt-7 FluxBeam-X LED Bulbs. The headlight bulb will work in your Fog Light as long as it's the same type (9005,9006 etc). They work on our trucks and they are 6000k pure white. They look amazing.
Opt-7 also sells a plasma led bulb made specifically for fog lights and they also have a Flux Beam bulb made just for fog lights.
www.opt-7.com
Sent from hell via TapATalk
mpress2570
mpress2570
www.opt-7.com
No 3000k though?
TheRudeDog
OPT7 - LED & HID Lighting for Cars, Trucks & Motorcycles
Which Opt-7 bulbs do you recommend for a 2013 Laramie? Also would color temperature would match up better with the stock headlights (until I find a LED replacement headlight bulb)? Thanks!
mpress2570
mpress2570
3000k (yellow) is amazing for cutting through fog that's what I want for mine
OnSale
5th Gen Crew
Philadelphia, Pa
Get the FluxBeam-X bulbs. Make sure you pick the X ones... they cost 109.95. The older version is the 99.95 ones. Get the new FluxBeam-X version. Brighter, Better, quiet fans, Better wiring etc.
Chisox
Putco Optic 360 is a standard plug and play LED replacement no ballasts or resistors and 6000K light that matches my LED headlights perfectly. $100 a pair
My headlights are from HID extra, they are RAZIR LED's, they match perfectly and come with the canbus module and it all fits inside the headlight housing.
mpress2570
mpress2570
I'm not trying to be an ass, but no wires or converters really just means not good quality. The power from the truck needs to be converted into less power for the LEDs. I think I found my brand thought. Unfortunately they don't come in the yellow I want but I think I'm going with gtr lighting gen 3
Ferro
I would like to get the OPT-7 Fog lights for my 2016 sport. Which ones do I need to gets very confusing. And are they plug and play. Thanks in advance.
OnSale
5th Gen Crew
Philadelphia, Pa
Yes they are plug and play and include everything you will need. The plugs are numbered so it's easy to hook up. Get the $109.95 set of FluxBeam-X bulbs. Do not get the $99.95 set as they are the 3+ year old set and are very outdated. The FluxBeam-X set (the ones for $109.95) just came out 2 months ago.
Ferro
Thanks for you help.
OnSale
5th Gen Crew
Philadelphia, Pa
No problem man... that's why I love these forums... so much information and you can find the answer to any question or problem usually within a few minutes.
If you have any more questions or you need help installing them, feel free to PM me.
TheRudeDog
So what you're saying is go with the headlight bulb FluxBeam X (which should match up with my stock projector lights in term of color temperature?) for my fog lights? And which bulb (H?/900?) do I need? Thanks!!
TheRudeDog
How do you like the RAZIR LEDs for your headlights and how long have you had them? My only concern would be heat issues with the dust covers on.
OnSale
5th Gen Crew
Philadelphia, Pa
What year is your truck? And you have the oem projectors?
