Bk flip and bed rug mods installed what you think
blackout11
alpharetts GA
2011 R/T
I have to admit these were probably the 2 easiest mods i did the rug took like 30 mins and the bak flip like 40
quietpeen
2021 TRX
Hellcat
love it!! I really need a bak flip since i already have a bed rug
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
love it!
needed a ladder for it though?
sullivan
Houston, Texas
Im sooo jelly, loove the backflip it really makes your truck look nice now
WhiteExpress
Midland, TX
Now I really want a BackFlip. Do the panels remove easily? Are there tracks on the bed rails? I don't quite understand how it all 'installs'.
I'd really like to get one, but I won't get something that won't let me haul the ATV.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
the panels aren't removable separately. There is a track that it sits on, on the bed rails. It sits on that, is bolted in at the front, and each panel has a sliding clip that holds it to the rail (operated by a wire under the panel).
It folds up against the cab, you will lose about 6-8 inches at the front.
quietpeen
2021 TRX
Hellcat
It should not prevent you from hauling a quad
WhiteExpress
Midland, TX
I want to be able to have the quad in the bed with the tailgate shut/locked. I can't afford 6-7" at the front. However, if it all sits up, not down in the bed, it might work. Crap.
Who wants to drive to New Mexico so I can try it on theirs? Haha!
blackout11
blackout11
alpharetts GA
2011 R/T
Ok just so you know i had 2 ktm 450's in it today with n/p and also it bolts on the front with 2 hand screw type bolts so all you would need to do is unscrew them and whole rhing would lift off.As far as the rails its attached with clips.
BakFlip G2 , HD Installation Guide
Check this out its a good vid on it
