Brake Upgrade??
blackgold2012
I'm about to install a 7" CST lift on my 2009 2WD ram 1500 and will be running 20x10 Helo wheels with 35x12.50 tires. I'm a little worried that my braking performance is going to go down with the bigger size wheel/tires.
Has anyone experienced any problems with their brakes after installing bigger wheels/tires?? Also, what brake upgrade kits are available for our trucks?
Stangshcky12
Oshkosh, WI
5.9 Cummins
I have a feeling that you'll be kicking yourself for only goin with 35s
I havent heard any complaints from guys running 37s even. Often times guys will refer to help get that truck going but stopping doesn't seem to be an issue
the codes
Houston, Tx
Magnum 5.2
id give anything nearly for disk all the way around haha
garner
Harker Heights, TX
The big brake upgrades for the 4th gens are from baer and brembo. Think they're near $4,000 for the front
BigH0ss
Banned
What do u need to upgrade to bigger rotors? Just different brackets?
The Assassin
B-more careful, Murderland
You will be adding more rolling weight, in turn increasing the distance needed to stop. I used my stock brakes on larger wheels and tires for several years. Did it work yes...but you could tell that it was wearing on the brakes. I couldn't justify spending several grand on a "big brake kit", so I upgraded to drilled/slotted rotors, and also upgraded the brake lines. My truck is now on 38's, and while it doesn't stop on a dime...it is a huge improvement.
Keep in mind his is a 2wd too.
The big brake kits typically include the larger rotors and more pistons. And yes, they would come with different brackets.
B
blackgold2012
Thanks for the feedback. So which drilled/slotted rotors did you end up going with? Also did you keep your stock calipers?
After the lift is installed I plan on having my dealership swap out my 3.21 gears for 4.10. So hopefully this will resolve the issue of maintaining performace with the bigger size wheels but really want to improve the braking as well without breaking the bank.
The Assassin
Brake Rotors Brake Disc Drilled Slotted Rotors Brake Pads
Kept the stock calipers, just had them powder coated. Your dealer is doing the gear swap? What are they charging you?
S2kiHemi
Houston TX
Some one needs to see if the SRT Ram brakes will work on a 4th gen. I loved them on my 05.
B
blackgold2012
Kept the stock calipers, just had them powder coated. Your dealer is doing the gear swap? What are they charging you?[/QUOTE]
Ok thanks for the link. Those rotors seem like a lot cheaper option. I would also like to have my calipers powder coated, just have to do some shopping around to see who does it and for how much.
I'm not sure how much the dealership plans on charging me but I'm sure it's not going to be cheap.
I was also wondering about the SRT-10 brakes......has anyone tried installing these on a 4th gen????
The Assassin
Not familiar with the 4th gen brakes...however I'm sure it could be done, but wouldn't be a direct bolt on by any means.
I have 37's and my brealks are stock. i have no trouble stopping. When i do need breaks i will get the slotted rotors as well. I wont be spending now 1k on a break upgrade though haha. These are what i am looking at...
Your Shopping Cart
Same page I posted. And you mean to tell me you don't see any change in your stopping distance?
S2kiHemi
Houston TX
I know the calipers won't just bolt up. You have to have the SRT spindles as well even for the 3rd gens. Someone would have to see if a SRT spindle would fit on a 4th gen.
shieldsdb
Midland, GA
Five.SevenlExpress
Fort Hood, Tx
5.7l
Rotors: Power slot slotted
Pads: Hawk pads
Ran me 500$ all the way round for my V6 04 ram... tend on doing the same cause stopping came alot quicker i noticed with the upgraded
The Assassin
I'm running 20" wheels with 35's. The truck stops just as well as it did with stocks.
Thats a good article but...Who the hell is repeatedly slamming on the brakes from 110mph? I don't think that break assessment applies to 99.999999% of the owners.
The weight difference from the stock wheels to 35's are very little.
