Broken dee zee tailgate assist
breal201999
I've had this assist on since shortly after I bought the truck about 3 months ago. Today, the ball that screws into the nutsert into the tail gate separated and now the nut will not thread back on. I called Dee Zee and they are sending me another installation kit in the mail... my main question is when I drill out that nutsert, is there a way to get that "mushroom" piece from the nutsert out so it's not rattling around in the tailgate?
clh1220
st Louis
Take the inspection plate off the tailgate.
stimpy433
IOWA
I'm on my second replacement lower ball.... they have great customer service just sucks to have to keep replacing it. Gonna try it with putting a nut on the inside instead of the zert next time.
PCT
2019 2500 6.4
Northern California
They have GREAT customer service... but I had to replace mine about 5 times
Sent from my SAMSUNG-SM-T817A using Tapatalk
TerraNewf
NL, Canada
Sounds like a possible error while installing...
Burla
2010 Hemi Reg Cab 4x4
I read the amazons and I still bought it, only 24 bucks if it lasts a couple years I will be ok. Sounds like they should just add a couple balls to each pack. A significant number don't last but many last a long time. It is likely an angle thing would be my guess, some must be out of whack even a little. Seams like the ones that break keep breaking. Amazons report the same thing.
sammon287
Pennsylvania
5.7, 8sp
I followed advice from a post in an old thread about this and ordered a stainless ball/stud from Amazon. It's installed with a couple washers and a ny-lock nut on the inside. Seven months with no problem and I don't anticipate any. Well worth a couple bucks for a permanent solution.
You can't reach the inside of the tailgate with fingers, so I held the nut in a combination wrench with blue painters tape to reach the bolt. It sounds harder than it is.
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
Thanks Boyd that seems the way to go...mine broke after about year
Ram Night
Southwest, Michigan
I installed one of these assists on my 07 Ram when I purchased it new, and it was still working great when I traded it in for my Rebel two months ago.
xrsman
Ontario
3.0 Ecodiesel
I had this happen on my 2014 and was sent a new kit.
On the second kit somehow the ball bent after time and became loose. I ended up welding it to the plate. That did the trick! Lol
No issues with the kit on my 2016 though.
B
breal201999
Over the Christmas break, I took the 'nut spreader' install tool out of the new install kit they sent me and thought I'd just try if I could grab more threads on the part the ball threads into and sure enough I was able to turn my wrench a few more times to get some more threads for the ball to thread into and has held up so far. At least I have another nutsert if it fails in the future.
Quint
Minnesota
2021 Big Horn 1500
5.7L v8 eTorque
The ball on mine just snapped off this weekend. I'm glad to hear about the customer service. I'll give them a call.
UnsatFC
Active duty NAVY
New Jersey
Mine broke the other week. Called dee zee and was told I have to call the shop that I originally bought it from to get service/replacement. I need a new insert and shock since that broke as well.
How do you get to the access port on the tailgate?
Quint
Minnesota
2021 Big Horn 1500
5.7L v8 eTorque
I just called DeeZee and they don't just mail you another ball for free. You have to buy another "bracket kit" for $10 that is essentially everything but the shock. He said that the two years that I got out of that ball is about par for the course.
UnsatFC
Active duty NAVY
New Jersey
I had mine on for a month before it broke.
spencer1122
Toronto, Ontario, Canada
2017 Sport
i never even got mine fully working before the ball came loose and i followed directions to a T. i almost destroyed the shock when trying to remove it so DEEZEE is sending me a whole new unit. +1 for customer service. they are great
Sportman
Canada, Manitoba
I haven't had any issues with mine yet. And their customer service was excellent when I had questions
ocwill1
Severn, MD
5.7 eTorque
I had a problem with the one on my F150 a couple years back, you can try the lock nut route, but I chose to drill and tap a new hole. Screwed it in with some loc tite and no issues
