Broken dee zee tailgate assist
Mugster
Ontario, Canada
I had one on my 2013 and never had any issues with it. I've bought another one for my 2017 but haven't installed it yet.
07MegaCabRam
Chandler, Arizona
6.7L CTD
Whatever the issue, let them know. They will replace. They have outstanding customer service.
UnsatFC
Active duty NAVY
New Jersey
Well that's not what I was told when I called. I'll try again tomorrow and see what happens.
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
I could use some help, if anyone knows how to remove the deezee hardware after the ball breaks off I'm all ears..
Drill the rivnut out like you do to remove a rivet. You step up drill bit size till the head pops off, then you get to fish the back side out of the tailgate.
SitKneelBend
St. Louis
3.6 Pentastar
Thanks, any ideas on a better replacement? Any special bit I should use to drill it out?
crash68
Administrator
3.0 EcoDiesel
You could try using a nut on the back of the ball mount but it's more work than it's worth. Get a new ball and rivnut and keep it lubed up.
Captain Bart
Michigan
345 HEMI
This is not installer error, its chinesium. Call them and they will send you another ball stud mount.....Figuring out a better mousetrap is on the mechanic.
I called and was cheerfully greeted by a wonderful lady, who sent me "5" repalcement kits, without the cylinder. The NEW fix is a solid plate with welded ball stud. That plate is still affixed to the side of the TG, with a nutzert, it is just much more robust. The original ball studs would bend from constant use, and snap off. Drive out the old nut zert, fish it out by removing the inspection plate (T-27), and install a new nutzert, as proded. The new plate is as large as the plate that mounts to the bed side. Problem solved in 30 mins....thanks DEe Zee!!!! Amazing customer service.
vhmike73
Watervliet, NY
2015 2500 Laramie Limited
Mine broke, but at the lower "socket" part of the strut. I have to call them to see what they'll do for mine.
vhmike73
Watervliet, NY
The ball socket, just behind where the metal spring sits, cracked on both sides: the ball won't stay secure in the socket. The interesting part is that it pops off when I put the gate back up (sometimes)...so the next time I open the tailgate is a crapshoot about whether it will be damped or drop without resistance.
SitKneelBend
St. Louis
3.6 Pentastar
Dodge 1500 4X4
Rochester, NY
If I'm not mistaken it's not cracked, that is how it's designed. The spring clip that slides into those groves is what retains the ball mount. You can try bending that clip to better retain the ball.
The Female plastic socket is split and the spring clip is buried between the split plastic housing.
BobSacomano
North Texas
3.6L V6
Sounds like a cheap, sh&$+y part, but then so many people own one, you probably can't say that out loud because personal biases make those people clap back at you to avoid the cognitive dissonance of being a person who purchased a sh&$+y part.
SitKneelBend
St. Louis
3.6 Pentastar
They improved the part several years ago with an updated design.
Livinalittle
Ontario
2013 Sport, 6 speed, 4x4, 3.92
Mine's pooched as well after a few years. I think it's just wear and tear.
I'm contemplating buying two more kits and installing on both sides but I'm not sure if it will be too much resistance.
JB1
Houston, Texas
I put a dab of marine grease on the ball end at the brackets when I installed mine. Here’s a pic of mine with the new style lower mount.
