The DodgeFather
- Feb 12, 2017
- 252
- 105
- 2012
- 6.7
I like them have a link .
Bump for people asking about link.Looks like red lens is now available. I didn't even get my other ones yet but went ahead and ordered these. I want to compare the two.
New red version just ordered:
http://www.ebay.com/itm/381950304805
This is what is arriving Monday:
http://www.ebay.com/itm/361891615708
Looks like a Ford.
yeah wow you have some dots in the middle still looks like a gmc tail light don't like them the taillights that ram has right now take it away from the pack because no other truck has something like them.
I'm just trying to decide if I want the smoked version, or the red version. With the Granite Crystal paint I have, the smoked would look good. But, having a Big Horn, I have chrome bumpers and grill, so I'm not sure if that would throw me off, looks wise.
I don't mind the red lenses... it would keep that "stock" look, so to speak, without being stock... if that makes sense. But, by getting that 3rd brake light also, the smoked version would match it better than the red. Decisions, decisions...
Does anybody know if there is a way to make these compatible with trucks that have OEM LEDs?
Man, I wish they had them for OEM led taillight. Looks like I will have to return mines unless someone knows a work around to get them to work with led taillights.
Unfortunately if you have factory projectors and factory LED tails, the aftermarket selection is slim! Hopefully someone chimes in to help you because I'd love to snag a set of those as well lol
well it would be tricky to do this but it can be done, you would have to hard wire since its not the same type of connections used between the two different style of tail lights, also you have to remove the Resistor pack from the new LED tails, the rams that came with LED tails and OEM projectors came with an electrical system not designed to run a standard halogen bulb, it will damage your system if you put a any kind of load other than just the very minimal one that an LED puts out, next you will have to do some slight custom wiring to a relay in the tail light, that is so that the computer will know that the tail light is working, its a different type of detection the truck uses since it cannot use the bulb load detection the normal trucks use....
it sounds more complicated than it really is, ive done the conversion before but its not a "just cut and splice these wires" kind of thing
Thank you for the reply and much appreciated. By chance you do you have any pics of the conversion you did for this.
They are pretty bright.
Yes plug and play for standard tail (non led)
For this model you have to use your existing reverse bulbs as they are not led.
