moparbay
- Nov 23, 2012
- 72
- 3
- 2015 Ram 2500
- Cummins 6.7l
Hey Guys,
I have a set of RetroShop's Projector Headlights 55w HID (quads) for my 2012 Ram 1500 Sport 4x4. Pretty much his basic kit with Halos.
Before I start i want to say that i have emailed JJ for instructions how to hook these things up as there were no instructions that came with the lights. It looks like JJ is busy with some things that may keep him from responding to current requests until March 19th. So I am asking for any help the forum members can help me.
First, the headlights cam with: 2 Morimoto ballasts /w mounting hardware, a main wire harness that hook into 2 relays with plugs for the 2 ballasts, a OEM input connection, a power connection, and 3 ground connections. Also included were 2 - 2 wire harnesses for the Halos which seem self explanatory.
Second, I have mounted both ballasts and the relays and plugged the relay harness into the ballasts. I have also connected all the grounds but have not hooked up the power to the relay harness.
Third, up to this point everything seemed self explanatory. The problem came up when I removed the driver side headlight and tried to hook up the OEM Input to the Relay harness. The relay harness has a 2 prong plug and the OEM plug is a 3 prong plug. Needless to say, I looked at all the plugs over and over again for about 15 minutes expecting them to magically fit together some how.
Ok, here are my questions for you guys: 1- Are these kits supposed to be plug and play (Except for the Halos)? 2- Am I missing a harness that will adapt the relay harness to the OEM harness? 3- if it turns out that i have to cut my OEM harness to make this kit work, is there supposed terminals and a plastic connector so I can plugin the cut OEM wires into the 2 prong OEM input connector on the relay harness?
Please answer any/all of the above questions if you can. Thank You
