Heat will be the only real issue. If a compressor gets too hot then it'll fail sooner but you have to lok at what your duty cycle is going to be. If you're running a complete air ride system it probably wouldn't be the best location just due to how often the compressor will be cycling but if it's for helper bags or to fill tires after a trail drive then it's not a bad location.
