Below, I'm going to list your 3 main choices that are your best options with some of them having multiple choices. I will list them below in NO specific order:
1a. HID Kit -
Price: $180
If you have the 13+ OEM Projector headlights then you can order a "drop-in", 100% plug-n-play kit from TheRetroShop
www.retroshop.us. Email the owner, JJ, and he will help you pick the proper kit for your truck so you get everything you need the first time, and get it done right. RetroShop uses Morimoto HID kits and they are one of, if not thee, best HID kits you can get. Period. Obviously if you have Halogen lenses (Dual or Quad Housings) you don't want to put HID's into them as you
WILL blind oncoming traffic and your light will scatter and not be as good as it could be in a projector lense.
• Quads - Morimoto Drop-In HID Kit
http://shop.retroshop.us/ProductDetails.asp?ProductCode=4G.HIDs
• Duals - Morimoto Drop-In HID Kit
http://shop.retroshop.us/ProductDetails.asp?ProductCode=4GD.HIDs
1b. RetroFit Stock Duals/Quads - Price: $400 - $1200
If you don't have the stock 2013+ projectors, then you can't get HIDs. Well... you
CAN, but you
WILL blind oncoming traffic, cause accidents, and you won't actually see any better because the light won't be shining properly without a projector lense. There are a few company's out there that do RetroFits. (
www.retroshop.us,
https://www.theretrofitsource.com )You can either send them your lights or they can start from a set of OEM lights. From there the options are endless. Check out the links at the bottom of this section for the custom light builder. You can build a custom set of lights exactly how you want. RetroShop can custom build you a set of Quads, Duals or Projectors. If you don't want to spend $1,800 on lights, you can order all the stuff you need and do the Retrofit yourself. (
https://www.theretrofitsource.com/complete-retrofit-kits/morimoto-retroquik-dodge-ram.html) It will run you around $400 for everything you need to do the retrofit. It's not that hard, there are 100s of walk thru's and how-to's online showing you exactly how to take your light apart, and how to mount the projector and reseal the light.
• Duals - Headlight Builder: http://shop.retroshop.us/ProductDetails.asp?ProductCode=4G.DL.RETRO
• Quads - Headlight Builder: http://shop.retroshop.us/ProductDetails.asp?ProductCode=4GQD.CUST
• 13'+ OEM Projectors - Headlight Builder:http://shop.retroshop.us/ProductDetails.asp?ProductCode=4GPRJ.CUST
2a. Opt-7 LED Bulbs - Price: $100 - $110
You can go with the Opt-7 LED's and order the FluxBeam LED Bulbs for $99 or you can order their brand new FluxBeam-X LED Bulbs for $110. I have a 10% off promo code for the Opt-7 site. If you want it, just let me know, i'll send it to you. Many members on these forums have said that the Original FluxBeam bulbs
(** NOT THE FLUXBEAM-X**) fit inside the Quad, Dual and even the 13+ OEM Projector housings with the ability to close the dust caps with no drilling or modifications required. As for the FluxBeam-X, some members have said they fit, while others have said they dont fit without modifications. I ordered a set of the new FluxBeam-X bulbs in size H11 that are going into my Retrofit Quads that were custom made by RetroShop. I can let you know how they fit, and how the output, range, color etc. is. Many members have reviewed the Original FluxBeam bulbs and love their color, output and range. As for the FluxBeam-X bulbs, they just came out in early November so not to many members on here have them.
FluxBeam LED Bulbs:http://www.opt-7.com/fluxbeam-led-headlights/
FluxBeam-X LED Bulbs:http://www.opt-7.com/fluxbeam-x-led-headlights/
FluxBeam LED Fog Light Bulbs http://www.opt-7.com/fluxbeam-led-fog-light-kit/
2a. Morimoto 2-Stroke LED Bulbs - Price: $130 - $150
Here is a second LED option. The Morimoto 2-Stroke LED Bulbs (
http://www.morimotohid.com/led-lighting.html/). They are a little bit more expensive than the Opt-7 FluxBeam series but then again, Morimoto makes the
best HID kits on the market, so I'm going to go out on a limb here and say that their LED Kits are probably one of the best, if not thee best. You can order a set of these from many different sites, I've seen them as cheap as $130 and as expensive as $180. But you can get them straight from the source, Morimoto, for $150. I have zero experience with Morimoto LED's, but everywhere I've seen their name mentioned online, it's always been 5 star ratings and excellent reviews. As for fitment into any of the 13+ housings, I can't answer that. Maybe another member can chime in and answer this from personal experience.
Morimoto H11 2Stroke LED Bulbs:http://www.morimotohid.com/led-lighting/h11-morimoto-2stroke.html
Morimoto 9005/HB3 2Stroke LED Bulbs:http://www.morimotohid.com/led-lighting/9005-morimoto-2stroke.html
Morimoto 9006/HB4 2Stroke LED Bulbs:http://www.morimotohid.com/led-lighting/9006-morimoto-2stroke.html
Morimoto 9012 2Stroke LED Bulbs:http://www.morimotohid.com/led-lighting/9012-morimoto-2stroke.html
09' - 12' Ram - Morimoto XB LED 5000K Plug-N-Play Projector Fog Light Kit:http://shop.retroshop.us/ProductDetails.asp?ProductCode=RM.LED
3. Halogen Bulbs -
Price: $40 - $90
If you don't have $180+ for HID's, or $100+ for an LED kit then you should just buy some really good halogens. I had Phillips CrystalVision's in my 06 Rams Headlights & Fogs and they were the BEST Halogen bulbs I have ever seen! They are almost pure white with NO yellow and they're SUPER bright (see picture below) with a slight tint of blue. These bulbs run $49.99 for a set of 2 at Pepboys, but if you use the in-store-pickup feature on their website, you can get them for $35/pair plus a mail-in-rebate for $20 for each set you buy, and end up costing $15!!! Amazon also sells them from $20-$31, depending on bulb type. Now, other members have raved about the Sylvania ZXE bulbs, but I have no experience with them either, but I've read nothing but good things. Amazon has them for $32- $48. As for any other brand of Halogen, I can't personally recommend anything else. I promise you the Phillips are the best Halogens on the market!
Amazon - Phillips Crystal Vision -
https://www.amazon.com/gp/aw/d/B00U1OLAJA/ref=mp_s_a_1_5?ie=UTF8&qid=1482313657&sr=8-5 -
Price: $20.19 - $31.49
Amazon - Sylvania ZXE Bulbs -
https://www.amazon.com/gp/aw/d/B005...lvania+zxe&dpPl=1&dpID=51Sclpz2YUL&ref=plSrch -
Price: $32.04 - $48.91
Conclusion:
Its really up to you what you choose to buy, it all comes down to your budget and what your willing to spend. But, for the love of god
PLEASE do NOT buy a cheap $40 eBay/Amazon HID Kit!!! If you MUST have HID's then you really only have 3 options. Get a set of lights custom Retrofit ($1,000 - $1,800+); Buy a Retrofit kit and do the build yourself ($400 - $800+); or buy a set of Aftermarket Projector Headlights off of ebay or Amazon ($209 - $600) and buy a HID Drop-In Kit ($180). Now I don't recommend the 3rd option, but it's atleast better then running HID's in a halogen housing.
Whatever you do, do not cheap out on the HID kit! It's somewhat ok to go cheap with eBay Projectors, but DO NOT buy a cheap $40, $50 or $75 no name eBay HID Kit. Otherwise, your just asking for trouble. With how these Rams are setup, you will have a ton of wiring issues, chance a fire happening or worse, shorting out your system, etc. The reason they cost $40,$50,$70 is because the materials used are cheap crap and the kits are universal for each bulb type, meaning if you order an h13 kit, the wiring is setup for the most common H13 wiring setup. That means you will most likely have to cut up and hack the wires to get them to work. Reverse Polarity, switch the high/low/ground, etc . The Morimoto kits, or the RetroShop kits, are made SPECIFICALLY for our Rams tricky systems and come with the plugs already plugged into each other. It's that simple.
Here is a picture of my 12' Ram with the Phillips CrystalVision 9145 Bulbs in my Fogs
Here is the list of bulb types our trucks take:
09'-12' Dual Headlights:
High/Low • H13
Fogs • 9145/H10
09'-16' Quad Headlights:
Low • H11
High • 9005/HB3
Fogs • (09' - 12') 9145/H10
Fogs • (13' - 16') 9006/HB4
13'-15' Projector Headlights:
Low • 9012
High • 9005/HB3
Fogs • 9006/HB4
2016 Projector Headlights:
Low • 9005/HB3
High • 9005/HB3
Fogs • 9006/HB4
Important Links To Check Out
http://www.lightbulbs4cars.com/ram bulb guide (09' - 17' Rams List Of Bulb Types)
www.RetroShop.us
www.TheRetrofitSource.com
www.LightWerkz.net
www.MorimotoHID.com
www.Opt-7.com
• www.LightHeadz.com/URL]
• [URL]www.AmericanRetrofits.com
This should help you get started... good luck and let me know if you have any more questions about what watt Ballast to get (35w/50w) or what Kelvin bulb to order (3000k, 4500k, 6000k etc). I can help with that.
Good luck....
