beavermosh
- May 8, 2013
- 56
- 27
- 2013 Dodge Ram Big Horn 4x4
- Hemi 5.7L 390HP
This tutorial will describe how to disable the automatic tailgate lock via the key fob and inside door controls on a 2013 Ram 1500 Big Horn. First I'll start with a list of annoyances/pro/cons.
Annoyances:
- Second lag (and noise) between locking main doors and tailgate
- Tailgate actuator locks/unlocks regardless of being already locked/unlocked
- Attempting to open the tailgate with something in the other hand yet the tailgate is locked because you are at The Home Depot
Pros
- Resolving annoyances
- Tailgate lock will not lock with inside door controls or fob
Cons
- Risk of tailgate theft
Tools required:
- #30 torx bit
- Zip ties
1) DO NOT remove the tailgate cap; it does not have to be removed contrary to my initial thoughts. If I didn't have a bedliner this would have been obvious.
2) Remove eight torx bolts holding down tailgate plate and bed liner if one is present.
3) Remove tailgate plate.
4) Make sure that tailgate is UNLOCKED.
5) Unplug actuator wiring harness and zip tie to unlock bar. Make sure to leave a little slack here because that bar does move about 1/2" when opening the tailgate.
Annoyances:
Pros
Cons
Tools required:
- #30 torx bit
- Zip ties
