I am wondering if anyone else feels like I do. I have a 2013 big horn hemi crew cab with 31000 miles. I have read a lot about shocks on this and other forums. I came to the conclusion that Bilstein 4600 had to be the shock for me. I used Bilstein once before on a 2012 wrangler and was pleased. I purchase the shocks and installed them. Now I wish I had my stock shocks back, because the tuck is rough riding, I can feel every bump in the road. The read shocks are hard to change you have to remove the wheel well cover, but I’m thinking about replacing the 4600 with the OEM or a cheaper shock. Has anyone else felt like this about these shocks.
Sounds like you made a mistake by purchasing the 4600 Heavy Duty shocks. You might be able to get away with leaving the rear shocks on it, and just getting a non HD shock for the front. The rear shocks would help out too if you do any towing or hauling.
Is your truck a 4x4? Or a 2 wheel drive? All the stock, 1.4, 2.1, 2.8" settings apply to the 4x4 trucks only. They do make the 5100 series shock for a 2wd truck, but you cannot adjust the ride height of the truck, with the shock.
I just did my shocks a couple weeks ago. I was able to do the rear shocks without removing the wheel well. I took out all the screws on the drivers side and it allowed me to kinda bend and push the wheel well just enough. So I did kinda remove that one. But for the passenger side, I didn't even have to take all the screws out. That might save you a little time since it sounds like you will be removing the shocks again soon.
A lot of people talk bad about the Rancho shocks. But most haven't tried their RS9000 series. I have and loved how you can adjust them. You can make the ride softer than stock or much firmer by simply turning a knob. Great for when the in-law's are in town and you've got some extra weight in the cab.
